T5 is starting to hate life.. What are some other options?
Kris
I'll prolly buy used.
My car see's ALOT of track time, not much highway time, alot of city driving.
I'll spend about $1000 for everything, maybe a tad more.
HATE auto's, so those wont work for me. Trying to get away from a manual trans, kinda liking the C4, but what else is there?
Should I buy a cheap stock C4 for $100 and build it up?
Unfortunately, I don't know much about transmissions.. =(
LAFENATU
Track time + T5 don't go together in the same sentence.
Buy a used Tremec 3550/TKO/TKO 500
2slo95fiveoh
Lawrence, Kansas
X2.. If you currently have a manual trans setup, swapping to a TKO etc.. would be your best bet.
I bought my TKO setup 94-95 with 3,000 miles on it for $1300 (trans, bellhousing, clutch, flywheel, alum. ds)
and i wouldn't have it any other way. It's performed without a hitch for the last 2 years for me, and I am not
easy on my car..
K
Kris
Im tempted to get a C4 from the junk yard and build it up. $150 for the trans, then do it up with a trans brake, valve body, etc.. My buddy says pro shifted trans are a blast to drive.
Paul
Is anyone else really confused?
Matts50
Maybe he means the Auto slushbox that came stock? It is a little misleading but that's how I interpreted it.
Paul
A viscous coupling by any other name, is still a viscous coupling.
Damn, Shaekespeare and Mechanical Engineering all in one quote. I rule.
LAFENATU
Takes a lot of work to make a C4 strong enough to beat the fack out of.
- C4 Transmission
- Reverse Manual Valve Body
- Hardened input shaft 24 or 28 spline
- Torque Converter
- SFI Flywheel
- SFI Pro Fit Bellhousing
- Custom Design Dipstick and Filler Tube with Lock Top and Hat Seal
- 18000 GVW Transmission Cooler the will handle summer street use
- Self Locking Torque Converter Nuts and Bellhousing Bolts
- Complete set of Fittings and Cooler Lines
- Neutral Safety Switch, Shifter Cable and Brackets
- Deep Aluminum Transmission Pan with Built-in Drain Plug
- Pro Shift Servo
- Nuts, Bolts and Misc. Hardware ? Everything you need!
- SBF Multi-Fit Blockplate
- Alto Red Eagle Power Pack Extreme Duty Clutches and Bands
That's the basics to a C4 that can take a beating.
Wat? That shiat is a nightmare on a DD.
K
Kris
Yes, sorry thats what I meant. My uncle is very good with C4's, he would be building me a transbraked C4.
LAFENATU
You can buy a direct kit from Performance Automatic to build one yourself.
K
Kris
You have me interested. Would you happen to have a link to this?
If it matters, my car is on spray. My buddy mentioned something about getting a nitrous convertor.
Im tempted to buy a used built C4, but Im a little uneasy about that because Id rather have something new..
K
Kris
Thanks!
Have any idea what this conversion kit costs? Im using my phone for internet, and it sucks and wont let me view everything on the page.
Well then, I guess Ill pick up a cheap C4 and get this kit!
LAFENATU
No clue..I would go through jdsperformance.com
They are a dealer for PA.
