Tach, fuel, and temp???
ryankelly10953
ok my dash is being a bisnatch...the only gauges that works is the oil pressure and the battery and the speedo...the fuel, the tach and the temp are no worky, also the lights. i checked the fuses and none are blown...what else could it be...i have autometer gauges but i want the stock ones to work, ecspecaily the tach and the fuel gauge. any ideads???
topless95
have you pulled the instrument cluster out recently? Why would I ask, well to make sure both of the wire connectors were put back in
Prob not the right answer, but I always try to start with the simplest solutions first
R
ryankelly10953
pulled it apart...all good, i guess a new cluster is needed...its funny because when i got the car the lights in the dash worked now only the blinkers, check engine, and battery lights work??. To me that dosent sound like a wiring problem...more like a bad circuit board. Any ideas??
94kingcbra
look at the back of the cluster, see if there are any opens in the circuit board...You might also want to check to see if there is a source voltage getting there, I forget the colors, but there are more than one...So one going out could cause your problem!
R
ryankelly10953
sweet... went to pick and pull and picked up a 94 cluster and all is good...its funny now when im not wearing the seat belt the low coolant light is on....i didint think clusters were diffrent from 94-95 oh well it works! Thanks for all the imput!
