Tach spun around
MyBoxersSayJoe
My tach spun around and is pegged on the other side. :rollinglaugh:
Anyone know how or what to do to fix is? If I run into the higher RPM's it'll catch and pull back to around redline, but then drop again.
Thanks!
phil_the_thrill
mine used to do that too. i could get it back using two different methods. the first, like you said, was to rev it to redline. that would get it back for me almost everytime. the other is to take the clear shield off your gauge cluster which actually turns out to be pretty easy. just two screws and a headlight know holding the bezel in. then some goldish torx screw holding the clear shield in.
MyBoxersSayJoe
MyBoxersSayJoe
preferably stock replacement hehe.
phil, it won't cause anything to break if you wind it back yourself?
