tail light swap
Green Hornet
yesterdays project..... from this
to this....
Green Hornet
Green Hornet
i never liked the 94-95 tail lights. i had a 96 b4 i had the 95. and i just like those lights better.
yesss another one converts.
Just saw you're in Downers Grove, that's actually my home town. I try to get back every year to visit.
the 94-95 flows with the back end sooo much better imo. But the traditional style, well its good for sequentials but otherwise they just look wierd on a sn to me.
robb15033
Northern Va.
Did you have to replace the wire harness also? I thought I remembered the 94-95 having one different size socket, or have a different style of lighting up when the brakes are depressed. No?
Mystic SVT
^^^yes you have to replace the harnesses with the 96-98, actually 96-04 use the same harnesses except for the 99-01 cobras.
Green Hornet
Green Hornet
you dont have to replace the harness. only 1 socket will not match up. you just have to be creative to get it to work
Green Hornet
Green Hornet
nope. the light is a lil too small,but the backing will cover the hole. so u can use a tiny bit of caulk so it will seal. then when you need to replace the bulb, use a razor to remove. then reinstall.
Nice light upgrade, i do like the Cat's eyes but light output sucks big time
only reason why i switched to 96-98..
