Need some advice. What do you guys think the better deal is? Are either/any "good" deals?
As cast Twisted Wedge Track Heat Heads, up to .600 lift, comes with copper exhaust gaskets, 1.7 Trick Flow roller rockers, adjusting nuts, heads have been used once. $1000.00 for all o.b.o (no shipping)
-or-
Older TFS twisted wedge heads, No miles on them. Single spring, will hold a 598 cam. No rockers. They have not been on a car. Been port and polished and valve job by Craig Caulk racing heads - flowed 310 on flow bench, 2.02 valves, springs, keepers, need to be put together. (May need rocker studs) $800 + shipping.
-or-
Matching Trickflow Manifold & Plenum with oversized throttle body for maximum flow $350 + Shipping.
Twisted wedge heads with rockers, steel push rods, with crane lifters, 24 lbs injectors and shorty headers $900 + shipping
$1250 + shipping total
Currently running 95 Cobra Upper and Lower Stock.
If the Ported are the best bet, would I be hurting my setup significantly with the lower plenum not being ported? ie - would getting the TFS lower and port matching be a good idea?
Will be running stock cam until I can get a TFS Stage I in there.
Thoughts?
:TY:
G
-or-
-or-
Thoughts?
:TY:
G
