The Torque Converter Thread
SnakedMark8
95-stang said:
I would really like to see much of that too, ie, could a standard motor benefit in any way from a higher stall, are they any good for daily drivers, and if so, what stall to get. I appreciate thats asking a lot. :)
Yes the NA from stock to wild can definitely benefit from a higher stall. With the 4R70W's gearing and the lock up TCs combined with the computer's infinite adjustability you can run considerable stall speeds and still be very streetable with these 4.6s. So 3600 - 3800 is not uncommon to run across on an every day street car where as back in the old days that would be considered insane. With the electronically controlled trans and TCs it's not like the old days where the vehicle barely moved until you reached the lockup/stall rpm. With todays computer controlled vehicles they can be programmed to help eliminate some of this bad characteristics. Then the TCs have evolved to a much better design that eliminates a lot of inefficiencies associated with high stall converters. In the old days they would butcher the stock stators and bend the fins which would give you more stall but cause a lot of heat. Now the higher end companies can computer design their own parts, test them on a dyno before they go into production.
With the small 4.6 displacement you don't have a lot of low end torque to allow quick off the line acceleration. Going with a higher stall to get you up and into the power band allows you to leave the line so much fast that you can expect to reduce your 0 - 60 times by 2 or more tenths. You will also have some substantial decrease in track times. I don't know what your set up is but a mild mod I would go with 3200 - 3400 rpms, leaning towards the 3400.
V
voidfinger
quick question... with that 550 Buck stall you were talking about what would the highest stall in that be?
SnakedMark8
Re: The Torque Converter Thread "PLEASE STICKY"
Were trying for 3500. Once it's built and tested we'll know for sure.
V
voidfinger
cool, i'm thinking of running a pi swapped motor so it will be like 10.5:1 CR and i'm thinking of doing some stage 1 or 2 cams. So i'm thinking a stall of 3400/3500 should be down my alley, i know that some say to do a 4k stall with like comp 270's and stuff but im not to sure i want that much.
DropTopPony
South Jersey
SnakedMark8 said:
I'm going to cut and paste from another thread to this on just to keep the info in the right place.
DropTopPony said:
Lonnie,
For my setup i was thinking i would need a multi disc or very good single...i will be @ 400rwhp/400rwtq alot of it down low in the rpms (PD Blower).
I'd like to have it be able to last as a dailydriver and hold up under the once a month street night 1/4 mile blasts. What do you suggest?
Also did JL send you over here? This is a good forum to sell your product....it hasn't been tapped yet :)
Maybe you should consider becoming a Sponsor and hooking us up with nice discounts.
For a PD blower you don't want to get crazy with the stall since you've got a lot of low end torque with these setups. It sounds like you’re going with a base kit. Chances are a little boost won’t be enough for you, it never is for anyone. They always want more power later on. As for stall, I would keep it below 3400 rpms. With a 450 – 500 rwtq 3200 rpm would work out great. A good single disc would such as my Stage III 9.5 inch would hold up just fine and more than likely be your last TC purchase for that vehicle. The Stage II that I’m currently working on will be a billet also and may be a cheaper alternative but it hasn’t been tested yet. If you don’t plan on exceeding 500 ft lbs then it may work out just fine for you.
You don’t need a multi disc for that level of power. The whole idea behind the multi disc is more clamping, holding force by having multiple friction surface areas. Most TC manufactures won’t mess with them for a gasoline vehicle because they can’t put out the torque a diesel can. So the only design multi disc setups are for diesels. Most factory diesel trucks now come with multi disc by the way. PI has a good design, it’s light and the actual mechanics of it work. The problem with theirs is that the piston flexes when applied and they use the paper thin friction material that won’t hold up. I’ve seen too many of these just burn up and contaminate the fluid causing transmission problems. Now if you come across a used one it may be worth having it relined with better friction material. I can have that done for you also. There’s a couple other’s out there that offer a multi disc but they are very heavy and as I found out the hard way don’t hold up.
With these type of TCs you have to keep the weight down and that’s hard to do with all the parts involved with them. Also size is another problem, you have to get all those parts inside that TC which is a small space. To do this they have to decrease the size of parts going into it. This includes the frictions. A lot of times the amount of friction surface area is only increased slightly over a single disc. The PI multi disc actually has less surface area than my Stage II single disc and it will hold up to more power than the PI.
With these two 10 inch TCs I’m working on they will be designed specifically for the budget minded without sacrificing the good parts. This week my builder will be taking the specs we came up with and assembling a product for testing. The Stage I will be a major step up from the stock Mach 1/ Marauder 11.25 or what other companies offer by relining these TCs. It will have 30 inches of high carbon friction material vice the 18 for much better holding capability. Using an 11 inch front cover and 10 inch pump. Upgraded bearings and new turbine hub and is designed for the 350 – 400 ft lb applications. Where as the Stage II will be will be an upgrade with billet front cover, with some other strengthening parts installed to hold up to 450 – 500 ft lbs.
No JL didn’t send me here but I know him, he’s a good friend of mine. I think he’s still running a TC from the same builder I’m using for these new TCs but a much more pricey unit. I initially didn’t come here to sell anything. I was asked to come here but 3 different guys 2 were customers but all three where getting conflicting answers for people. I was told that Dallas Mustang was already a sponsor but they don’t interact with the site unless they are selling or have a sale. My idea of a sponsor is someone that also interacts with the site. I sent an email and PM to the site’s admin to see what it takes to become a sponsor but haven’t heard back.
Thanks Lonnie,
I'm content with 400/400 and 8psi on this car as its a vert and just my weekend cruiser...i just like it to have enough umph to shut up the idiots i encounter in the imports while enjoying my rides.
After i am finished i will get ahold of you about a nice TC for me and i will have a fresh dyno to show you before i need a new TC so that will help.
Oh the reason i asked if JL referred you here was i have seen you post on other forums and seen him interact with you in your threads :)
Contact Dalamar on here if you want to become a Sponsor....we could use one who actually is around to provide tech about his products.
SnakedMark8
[/quote]
Thanks Lonnie,
[/quote]
Yeah I know what you mean about the ricers. I'll have to send Dalamar a PM. I haven't heard anything from admin. Thanks
Dalamar
SLC, UT
I'd like to see a thread with the info starting in the first post, for a sticky.
What do you think Bob?
V
voidfinger
thats fine, i guess torque converters isn't a sticky worthy topic lol
Just trying to bring some info in since no one cares to talk about it on here and a lot of people ask questions.
Jrgunn5150
Jeff's saying he wanbt's it in a more organized, write-up kind of fashion to sticky it.
Dalamar
SLC, UT
The info is good, and like JR said, a sticky should start with the subject at hand.
whoever wants to make it, I'll sticky it. Srry, I don't have time to reorganize this thread.
V
voidfinger
I'll take the info and reorganize it tommorow and I'll put " Quotes " so to let people know that most the info came from Snakedmark8 and you other guys can post up in there also. That cool with you dal... pm me please on how it should start out and all b/c i'm not sure if I should jump it right in there or lead in and so on and so forth. Thanks
V
voidfinger
ok, thanks guys... I'm going to write this up in sticky form :) and get it out. ummm, not going to have time in the next couple days so i'll get to it asap... if no word in a week.. please pm me and remind me ... short memory ya know lol.
