Yes I have, my car has one in it currently and its a 95.
When you do the swap go to your local parts store with a brake line coming off one of the calipers and get hard brake lines with correct fitting for it. On your GT the fitting off the T-block is the same size as the line that goes into Cobra caliper's brake line (rubber or stainless steel braided little line) but it becomes smaller for a GT's caliper
I have the part number for the correct hard brake lines from autozone. It's PA-330. 2/16" x 30" 4.7mm x 76.2mm.
You're gonna need a line bending tool and a brake line flaring tool to cut it and modify it to the correct dimensions.
Lemme know if you have anymore questions.
itsblue95 said:
sounds like you done an IRS swap before. ive heard you have to change the brake lines or something like that?
