Ticking Valves
94kingcbra
I have a ticking noise that's been getting louder coming out of my passenger side valve cover....So, today I did a quick teardown down and found a loose rocker arm...I figure it's normal since they haven't been adjusted since the motor was built. All I am asking is can someone tell me the correct way to reset the valve and rocker spacing. I don't want to just tighten down the bolt and hope it works. I want to loosen every bolt and re torque them. I'm gonna have to turn the crank by hand, so the minimum ammount of turning possible... I also need info on centering each hydraulic lifter equally, does 3/4 turn past hand tight, then lock the stud sound right? All help is appreciated as always...Thanks guys, Justin
topless95
wayne94mustang said:
you talking bolt downs or stud mounted rockers?
it reads like you have both...lol
are they pedestal mount or stud mount, because they will be two different procedures
94kingcbra
Sorry guys I wrote that after a long day....Here's what I am looking at...When I first built the engine I was planning on doing studs only...But my engine builder suggested a girdle, and he sold me on it....It's a stud girdle
[attachment deleted by admin]
wayne94mustang
for stud mounts i go to zero lash (i like to twist the pushrod in my fingers and when i feel resistance thats what im calling zero lash) then i only go 1/2 turn more.
for the order of how to do it go to comp cams site
94kingcbra
that's what I did...and I fixed a header gasket that was leaking again...runs great again!
96GTPlanB
