Timing cover - does it matter?
red9535
I've come to realize that the block has another difference that I overlooked in my build:
My motor is out of a 91-92ish Grand Marquis.. Whatever the last year they made the 5.0..
To my understanding, the 1983-1995 Mustangs, Mark VII's, T-birds, Cougars, and Explorer 5.0's all had the HO motor, which used a reverse rotation (counter-clockwise) water pump and front cover. The "Full Size Cars" (grand marquis and crown vic) used standard (clockwise) rotation pumps and timing covers.
So, as far as I can understand, the block doesn't care which one you use. You just can't mix and match the 2 (cover and pump). So right now, I have the timing cover from a grand marquis on my grand marquis motor (clockwise rotation), but the water pump I got is for a Mustang, and I have it rotating counter-clockwise. I'm starting to doubt that it's going to work.
Now, am I correct in this assumption? Will it work? If not.. is the answer to get a Grand Marquis water pump, or a Mustang timing cover? I dont believe I can just run this pump clockwise - it would just stall the coolant, correct?
It doesn't seem like the front timing cover would have that much of an impact on which water pump you needed to use.. I read this somewhere, and I'm not sure if its a legit source or not.. doesnt the only effect the timing cover has on coolant flow is the 2 small water jackets where coolant flows through? Even then, I don't see how it would make a difference..
can someone clarify for me please?
ranger50toy
I believe you will have to use a waterpump and timing cover for a 94-95 gt or the pulley will be in the radiator.
ryclef331
You need to have the correct pump for the rotation of your motor basically. If it bolts up, rotates right, and belts line up....call it a day.
