Timing cover gasket
gnx547
When installing the timing cover, do I put the gasket in dry? Or use RTV on both sides of the gasket? What do you guys do?
ProKiller
PA
i put a very thin coat just to give it a tackyness when applying it. remember there is a water passage through it so it's best to err on the side of over protection.
Paul
I did a thin bead of RTV. Check my notch build thread for pictures.
gnx547
gnx547
I put the gaskets will a little rtv to hold them in place. I got the cover bolted on and my dumbass forgot to lube the chain with some oil. Does the chain need to be lubricated?
whiplash473
Northern IL
I put a line on both sides..just enough to where it barely squishes out (then I wipe off the excess RTV).....I think you'll be ok with the timing chain
Sent from bored/stroked iPhone
gnx547
gnx547
Also, I notice before I put the cover on after I torqued the cam bolt, I turned the engine over with the ratchet, and it feels like the chain was skipping, it was not smooth, like it was not gripping and then after a few turns it was smooth and fine. I looked at the chain and all the teeth are on the gears. The marks are still lined up correctly. I don't know what happened? Or why it did that? Is that normal?
