Tire Question
sonicblue03vert
Dartmouth, Mass
Ok, so, I just picked up my 03 GT Convertible, and the wheels are aftermarket. The rears have 245/45/18s on them, now I know my speedo will be off, but I am getting an SCT tuner to fix that very soon. My main concern is the front. The fronts have 215/55/18s on them. Will I have any issues with that? I am not autocrossing or racing, just cruising around during the summers, and the tires have lots of life, so I don't want to get rid of them. Any input is much appreciated.
07GtS197
Fort Myers, Fl
If you have abs the difference in tire diameter may set off abs thinking theres wheel spin. And its a little odd that the fronts are taller than the rears.
sonicblue03vert
Dartmouth, Mass
Yes, it is odd. But, the tires are not stretched In anyway, just a skinnier aftermarket front wheel. and the alignment is dead on, because I got it aligned when I replaced ball joints. Just thought it was odd tire choice on front. but, if it wont affect anything much, I'll roll with it until I need new tires and address then
RAU03MACH
NEW MEXICO
Are your tires off set
A picture might help just to see how it looks
I never heard of that combination or set up
Just wondering
sonicblue03vert
Dartmouth, Mass
[/URL]
Like I said, doesn't look too bad. I may wear these 55s out, and go to 45 or 40s when they need to be replaced.
95opal
Never saw anyone run a taller front tire than rear but hey not my car.
215/55-18 245/45-18 Difference
Diameter inches (mm)
27.31 (693.7) 26.68 (677.7)
sonicblue03vert
Dartmouth, Mass
Yea, I just bought the car, and the person who owned it before me hacked this poor thing together, so I'm just fixing a lot. I'll just put it this way, when i bought it, rear brakes were so bad, the pistons from the calipers were pressing directly on the rotors!
Sent from my SM-N975U using Tapatalk
RAU03MACH
NEW MEXICO
Sounds like you have your work cut for you
As you make changes or up grade send in those pictures
Not a bad project car
Have fun with it
sonicblue03vert
Dartmouth, Mass
Ok, so I've decided to ditch the wheels, and go with 10 inch wide in the back, and nines in the front. I know the front will be fine, but, will I need to roll my fenders or anything for the rear?
evilcw311
Most Evil Member!
Louisville, KY
If not dropped then you’ll be fine. But if you decide to drop you’ll need a heat gun and either a Louisville slugger or Eastlake fender roller.
