TIRES HELP!!!!!!
Cali95gt
I have a problem. i have some nt555 255/40/17 on the rear. my fronts are gone. so i will be rotating them to the front and putting 275/40/17 on the rear. this is where the problem starts:
Car is a 95 GT
go to the tire place. the 255's are to big for the front. seems odd to me since i hear of some people running 275 up front. went to Nubbe motorsports and they told me to it will be a tight fit. is there anything i could do to make the 255's fit in the front. i really dont want to get rid of them, so any advice would help. if they can't fit then i'll trade for some 245's i guess
joekd
Ct
What rims are they on? Is it a backspace issue?
I have 255's on OEM bullitts and they fit fine, not a bit of rubbing
C
Cali95gt
they will be on 17x9 1995 cobra r's? just weird that they don't fit in the front when everyone seems to have this size or bigger?????
Win
Kennesaw, Ga
They will fit I put a 275/40 on stock Tri Bars it fit just fine. I ran a Falken Ziek 512 with very very little sidewall bulge. If there going on a 17x9 a 275 is the recommended tire size for that rim
kintek
they will fit for sure I run I believe 275 on my 95 Cobra R's. Tell the people they need to go back to school. they dont know what they are doing obviously.
TxCobrA98
lol, 255's will be no problem on the front 17x9. i run an 18x9 and have run 265's up front before.
Christang95
275's on the front and rear for me and no problems at all. Need new rear tires so I might buy some 255's and switch the front and back
Rice_slayer
Im running 18x9(or 9.5, can't remember) and 275s all around, rub at full lock at thats it, not other real issues at all. Those guys are stupid at that shop.
C
Cali95gt
i feel that they are stupid as well but the guy put the tire on the rim and it was rubbing the front stut a bit when it would spin. so what could it be?
kintek
had he just set it on the front rim without tightening it down? if so he had it at a angle and thats why it was rubbing. Your alighnment maybe off other wise.
mikey94gt
they are probably going by the tire fitment guides, which spec out a stock wheel/tire size. that is fine if you are running stock stuff, not so much with aftermarket.
