Tps question
97_281gt
Will a tps that's is throw the p0122 code (I think don't remember for sure) would it make the idle stay high? Like when I'm driving if I push in the clutch at 3 grand it stays there if I let the clutch back our and the rmps drop to 2 grand then push the clutch in it stays there. Would that code make it do that cause if the tps isn't reading correctly?
Ps the tps was already swapped with another one and still did it
97_281gt
97_281gt
Not yet I work graveyard just woke up
97_281gt
97_281gt
It started normal? What's it suppose to do
Not run good. Should have been a completely different sart up from your start ups now. Shouldnt idle or run good, .....did you try driving it? TPSensors will read partial and be intermittent when they go bad.
97_281gt
97_281gt
It started fine but broke up and drove like shit
If their are no other recent mods performed and the high idle just started, I would be pointing at the tps or IAC valve.
97_281gt
97_281gt
I just bought it it doesn't have a high idle when you just sitting there it's only if your driving and you push in the clutch to cost where ever the rmps are when you push in the clutch is where they stay
97_281gt
97_281gt
And I've swapped the iac with a known good one I'm gonna try to adj the tps tomorrow and if that doesn't work I'm gonna swap another one on it and see what it does
Was it 5spd swapped or tuned recently? I know mine did that when I put the 5spd in it before the tune.
senior001
