traction control?
F
FullThrottleStangs
i think mine is broken. i spin tires all day with it on.... :dontknow:
F
FullThrottleStangs
oh and one random question:
ive noticed that when im shifting, say from first to second, its not one motion; its two. from first, to neutral, then to second. why does it do that? i tried to just go immediatly to second, but it wouldnt work.
F
FullThrottleStangs
1OF723 said:
Do you have a short shifter?
nope and really want one after i shifted the 2011 gt500. it was a breeze
atlanticblue98 said:
because neutral is between 1st and 2nd...
yeah i know lol. but i get anal about the weirdest things and id like it if there wasnt that pause in between gears if that makes sense haha
F
FullThrottleStangs
96_SVT_Cobra said:
try and shift faster instead of pausing :dontknow:
lol i tried that.... didnt work. it just felt like there was a wall there. still same result.
it's possible, there's no way i could know over the internet. I cannot slide my shifter from 1st to 2nd though, it's like it hits a notch between the gears. sucks cause i can't really race the car like that.
F
FullThrottleStangs
THATS EXACTLY WHAT IM TALKING ABOUT. oh no :( could this be a contributing factor to my misfire or anything?
mygreengt
South Dakota/ Iowa
your traction control isnt working correctly. if i were to drop the clutch in 1st it wouldnt spin, its almost like the motor cuts out. its kinda annoying.
joekd
Ct
Need to know more about how much you are spinning, if you can spin them continuous for more then a few seconds then it's not working right
Try it in the rain, floor it and see how long they spin, you can break them loose then your trac cotrol should kick in and you will know when it does
Also is your trac control light on or off?
Lastly if your car has an aftermarket tune a lot of owners turn it off
I can't see it having anything to do with a misfire or your engine running poorly, it's strictly transmission related. Also a short throw shifter just makes the shifting worse.
96GTPlanB
