Tranny noise
bleau
I was rolling down a hill in a traffic jam so I put my car in neutral.
My car was making a bad noise like clunking.
My stick was pulsing with the clunk.
I pushed my clutch in with no luck then I put it in gear and the noise went away.
Any Ideas?
Its a 96 with only gears and exhaust.
B
bleau
I should of noted that when I put it in gear I kept the clutch depressed.
I talked with a guy today who said it might be the output shaft gettin loose.
scarface
My old t45 made that noise also, kinda sounded like it was rattling around in neutral. I changed to gm synchromesh, and it helped some.... It eventually died though.
Jrgunn5150
Yep that could also be it. Anything in the rotating driveline really. It goes away when you put a load on it, so that narrows it right down. I would check the U joints first, they are common and it's easy to eliminate.
B
bleau
Thanks guys.
I think I will pull the car off the road early and take it apart checking the ujoints first.
Anything I can do to that trans so it will last a long time as far as rebuild?
Or a good substitute.
Jrgunn5150
If it comes to that I recomend you go straight to either a Tremec tko 500, or T56. I've been through 3 T-45's, they never could hold up. I know it's alot to swallow, but you'll be money ahead in the long run.
UnNoticed46
my tranny does the same thing, it doesnt even do it very often. wish i knew what it was. it cant be u-joints since it does it when just idling and sitting still
