transmission crossmember...
FastFox37
Are all SN95 transmission crossmembers the same?
For example, will a transmission crossmember from a 1998 V6 work in a 1994 GT?
I am putting a T5 from a 1999 V6 in a 1994 GT with a Lakewood bellhousing. I have already swapped the input shaft and don't need a speedo as this is a track only car.
I purchased a 1994 GT roller but it did not have a transmission crossmember. The local "pick a part" is plentiful with V6 SN95's...
SVTstang96
Dubuque, Iowa
I think the v6 ones will work. Since you can use the v6 t5 on the v8 5.0 also. I have one if you need one.
F
FastFox37
Thanks SVTStang...
Do you know if the crossmembers for the automatic SN95's are different from the manuals?
If they are different, do you know the specific difference?
I expect I will have to do some fabrication due to my conglomerated combination...
F
FastFox37
Just as FYI if anyone else is looking for this information in the future...
I went to the "yard" today and pulled a trans crossmember from a 1995 V6 with a T5. When I got home a buddy of mine had stopped by and left a trans crossmember from a '95 GT with a T5 next to my door. He said that he had forgotten about it and found it in his garage this morning. Anyway, the V6 crossmember and the V8 crossmember are identical.
