Transmission pops out of gear
Phoenix0783
In my '97 Cobra when coasting in third gear, on a flat or downhill, it has a tendency to pop out of gear into neutral. It doesn't always do it but it's not uncommon.
Ideas on cause? If it's not a sign of anything serious I'm not going to worry about it for now.
3.14159
PNW
Sounds like the dogs are worn from running with bad synchros and grinding during shifts. 3rd gear going bad is pretty common on pretty much every manual.
P
Phoenix0783
I've never experienced any grinding, either from the clutch being worn out or me missing the shift. Still shifts fine otherwise.
lwarrior1016
Mr. Secondary Timing Chain
Staff member
South Mississippi
Does it have the stock shifter? Aftermarket shifters have shift stop adjustments, make sure they arent holding the shifter back from going all the way in gear.
evilcw311
Most Evil Member!
Louisville, KY
Could be a quart low on blinker fluid............ [emoji1787]
