trick flow cams
cobra head
ok guys i need a lil in put im ab to order my cam this week and i want to get a lil info from yll i have some trickflow twisted wedge heads and wanted to see if the trickflow stage 2 cam would work good for me and i wanted to see if any of yll have ran this cam
we would need to know more about the car, and what you want to do with it to tell you if the cam will work or not. I have a stage 1 I use I am happy with.
cobra head
cobra head
well im going to be running 1.7 rocker i have a cobra intake long tubes x pipe and a mac catback and next year putting a s/c on it like a powerdyne the car will be tuned i just hear alot of bad things ab that cam around here just wanted your guys input thanx
I have not head anything bad about the trickflow cams in general. Now is this for track use, daily driver, occasional track use?
itsblue95
Louisville Kentucky
TFS2:
224°/232° .542"/.563" valve lift w/1.6 .339"/.352" lobe lift 112° LSA 107° ICL /117° ECL
Events @.050" tappet lift are:
Intake Open: 5° BTDC
Intake Close: 39° ABDC
Exhaust Open: 53° BBDC
Exhaust Close: 1° BTDC
f cam specs:
Roller Cam1.604° BTC42° ABC52° BBC6° BTC288°288°.320 I.512 I109°119°
226°226°.320 E.512 E
No where near the same. I run the TFS1 cam and love it. It pulls hard! It also sounds pretty damn good if you ask me.
hear is an idle clip of mine.
http://www.youtube.com/watch?v=-SDJv0EkVX8
also if you run the tfs2 you may want to check your ptvc. good luck
96TANGERINEGT
When I put a cam in my last car . I called comp cams told them every thing that was done , and they gave me a recommendation to run . Baught it and it was awesome took the Ford motorsport z cam that was in and put in the trash . I had staggered rockers tho 1.7 intake and 1.6 on exhaust
Don't hurt to call a tech for info.
cobra head
cobra head
TFS2:
f cam specs:
Roller Cam
1.60
4° BTC
42° ABC
52° BBC
6° BTC
288°
288°
.320 I
.512 I
109°
119°
226°
226°
.320 E
.512 E
thanx for the reply blue
g36 monkey
Orlando, Fl
That's a big freakin cam. Should lope like hell. Shouldn't have much problem with creating vacuum because of the shorter durations (they are long to some but compared to others....)
I think it'd be ok for a street strip car, but it's really up to you? Are all the cams the same price from trickflow. I got the biggest I could from comp because they were all the same price lol.
Mrstangerbanger
CHICO , California, United States
Thats a great cam but if you are not running a good head( Better then Stock ) it will hurt you more then help you so I would go with the stage 1 cam for sure .. And I was thinking of the X cam not F cam Sorry lol .. I have a little bigger cam then a stage 1 and I have a Vortech blower and the cam pulls to about 6000 and thats when it stops making power .. If you are going to add a blower I would go with a stage 1 or leave the stock cam and degree it 2 degrees..
If you are going to build a blower car then you can build enough power to slit the block with boost so its up to you .. Also if its your daily driver or not ?
F303 226* duration, .512" lift
X303 224* duration, .542" lift
96TANGERINEGT
Ford motorsport cams suck ..... took a z cam out baught a comp , ran much better
itsblue95
Louisville Kentucky
they are not as bad as everyone makes them out to be. as matter of fact the f cam is suppose to be one of the best off the shelf cams for boost.
my buddy old set up ran pretty damn good with a x cam, afr185s, and a blower. it was NEVER beat on the street by any car even a 800whp evo.
thats what i thought lol
96TANGERINEGT
Ya there not that bad .. I have a lot of old school guys running some fast cars with them but then again there also running old gt40 aluminum heads and gt40 intakes lol ..
They r ok if u just have normal bolt ons . My old car had a comp and I love them . 214 degree. 224 and 232 with a 512 lift 1.7 rockets on intake and 1.6 on exhaust . Speed density car too. W / 24 lbs injectors . All my friends told me the car wouldn't run
