Trick Flow Upper and Lower
lilj4u2njoy
Forest City, NC
Okay, so i have this trick flow upper and lower with a 1" spacer, i need the two long bolts that bolt into the top, my stock bolt is too short i believe and i went to lowes tonight and bought a inch longer bolt but the head is a little to big for it to sit down in the hole... has anyone ever dealt with this? i went on trick flows website but the longest bolt they have is 7inches, which is the same length as my stock bolt i believe... does anyone know where i can get these two damn bolts at lol... thanks for your help
San Antonio, TX
Just take the bolt you have thats too short. Go to Home Depot and match it up....or get some threaded rod, a couple nuts and make some studs. Shouldnt cost more than $10
ivan12
Glad you found them, you really can't just go to home depot and get one. You might be able to find the length, but the originals have a button Allen head that sit flush in the intake, a regular 6 point head wouldn't fit in the hole.
5litrarag
Yup been thru that before... its a proprietary bolt spec. So you arent gonna find it on the shelf anywhere. Just bend over, grab your ankles and order from summit.
lilj4u2njoy
lilj4u2njoy
Forest City, NC
I did, it was pretty painful... No lube.....
Sent from my PC36100 using Tapatalk
lilj4u2njoy
lilj4u2njoy
Forest City, NC
Yea I prolly bought the same ones, heads are too big for the holes, so idk, I bought the ones from TF , problem solved lol
