trouble with my interior light
carsten
Germany
Hi,
does anyone know how to switch out the interior head light at the top of the inside ...I mean the reading light, inside the car.
I have remove the bulb because it lights all the time and I have no idea to put it off.
sorry for my bad english, I had tried to explain as best I can.
Here is a picture of the light I mean
It is the light in the middle, not the 2 little ones. It is really freakin me out
Greetings Carsten
DeepList
Auburn, IN
This is pretty common problem. My old 99 V6 used to do the same thing. You probably have a sticking door switch. It's inside the door mount to the door latch. Spray some WD40 into door latch and then open and close the door a few times. This worked for my car. If spraying it doesn't help, you might have to replace the switch.
had the same problem. the "button" in the the front of the door that gets pushed in when you close the door wasn't lining up with the part that pushes it down. Bent the part that pushes it back into alignment with the button and it was fixed.
masonlvvy
hi,carsten,if not sure,you can get help from the guys that have done before...may be your friends know how to remove it.........
