TTSaleen's Terminator Cobra Project!
TTSaleen
TTSaleen
NC
Burninriverdiver
Nice job on the outline! I probably would have messed up putting those on there straight
TTSaleen
TTSaleen
NC
Thanks guys.
The water/soap helps when you don't get them right the 1st time. LOL!!
I had to redo each one repeatedly!!! Probably shouldn't have started the project when it got dark! DOH!
Flashlight install for the win!
TTSaleen
TTSaleen
NC
So on Saturday I decided to replace my stock clutch cable, plastic quadrant, and add a firewall adjuster to the Cobra.
Install was pretty straight forward and it is a better upgrade (especially getting rid of the plastic adjuster).
Grabbed a few shots @ Fastlane and then one of the G8 after I cleaned up both cars.
BMAC96GT
Virginia
What cable, quadrant, and adjuster did you go with? And does that still have the stock clutch in it?
bumblebee
Dream car right there!
Now it only needs a turbo, or a couple of them :D
Check out my build if you haven't, not as clean as yours but I try..
TTSaleen
TTSaleen
NC
It's the Steeda stuff. We sell it @ Fastlane so I get a sweet employee discount. LOL!!!
It has an aftermarket clutch, not sure of brand, but the pressure plate is RED. So it's probably a RAM I would suspect.
A little stiff, but appears to hold just fine.
I plan to pull the T56 eventually for the 26 spline input shaft upgrade. I'll replace the clutch with a McLeod twin disk at that time.
Ryan
TTSaleen
TTSaleen
NC
I have been following your progress also. Looks great!
g36 monkey
Orlando, Fl
Awesome! I was just talking to the guys at VMP about you, actually talking about where I learned about the clay thing lol
TTSaleen
TTSaleen
NC
So are you holding out on me bro?
You got a direct connection for a VMP hookup? :tongue3:
What's the SN95 discount? LOL!
Oh and NANOSKIN for the win!!
I just did my truck with Nanoskin clay and then Sealer this past week.
Check it out.
evilcw311
Most Evil Member!
Louisville, KY
Do you detail for a living?!?! Everything you own always looks so insane!!!!! Lll
TTSaleen
TTSaleen
NC
Thanks!
I actually perform detailing services on the side.
It started when I was trying to learn how to detail my own cars. I started getting requests from friends to do their cars and eventually worked out a range of options and prices. My typical detail jobs take between 8-12 hours.
Ryan
BMAC96GT
Virginia
[MENTION=16025]TTSaleen[/MENTION] I've been looking into nanoskin a lot. It's got to be a ton easier than clay. I'm assuming you use the orbital attachment?
TTSaleen
TTSaleen
NC
TTSaleen I've been looking into nanoskin a lot. It's got to be a ton easier than clay. I'm assuming you use the orbital attachment?
I love my FLEX 3401. Set it to the lowest speed with the Nanoskin pad. Apply clay lube and run over a section at the time and wipe dry. Continue till all car is done including all glass.
Easily removes contaminants in a matter of minutes!
T's Convertible
