Sn95 matt
- Joined
- Jan 4, 2022
- Messages
- 33
- Reaction score
- 6
I have a stock 94 gt rn in the next few weeks i plan on put gt40 heads and trickflow intake will i need a tune for this stuff for it to run properly?
If i got to 24 pound injectors will i need a tune?Well it depends on witch head gt 40 is a head design
Name
Ford racing make many of them
You get the plain Jane with intake you won't need the tune
Ok thank you for sharing your knowledgei dont think so
i had pretty much the same set up and did not require a tune
Also did you port your out or do any work or did you just clean them up and throw them on and did you notice a gain and or a diffrence in general?i dont think so
If you install 24-lb injectors, you will need a tune or a MAF meter calibrated for them, otherwise the computer will dump too much fuel thinking its still pulsing 19's. The computer should be able to handle the heads and intake alone, but toss a cam onto the mix, and you're 50/50.
