Orange 94
Also, I'd rather support and meet a local tuner rather than have some micky mouse on the other side of the world take my money and give me a tune.
explain this. How do you feel 351hp rather than 349hp?
I could care less what you say. Its always better to have a person with the car.
Ideally you'd have the tuner drive it and have it on the dyno. Thats expensive and not always available.
I'll always be a strong believer it dyno tuning.
the 1/4 mile calculation CANNOT be disputed, take a look at some of the supra / terminator folks, some make some serious power but still can't get out of the 11s to save their life
would you rather a 1000hp supra that runs 11.9s or a 350hp fox with an explorer engine swap and cam that runs 11.8s ???
Even with those setups good tuners record what they do. So once they know what works for what setup, they can then use that data to properly remote tune another car with the same mods.
Yep, for bolt ons, an email tune is just as good as a dyno tune. You obviously might be able to squeeze a FEW more hp out of a tune on the dyno, but it doesn't really justify the cost.
it doesn't exactly work that way, the only things you can really take away knowledge wise are an idea of ignition timing and airflow modeling
the MAF sensor is what the tune is based on, you can have two identical setups with different MAFs and you'll have two completely different tunes depending on if one of the MAFs have to be scaled, granted it should be a percentage of the other tune but it doesn't always work out that way
if all you have done is bolt ons a dyno cant get you anything more than an email tune can, unless you get an email tune from "mickey mouse"
Dude. I never said the tuning would be EXACTLY the same from one to the other. But each tune you do with each setup on certain cars gives you more and more knowledge of what will and what will not work. Other than already knowing what you are doing.
Your nitpicking over a few words here or there. I was putting it a different way while agreeing with you.
But I am done talking in here now. Good day sir
