Under size pulleys
3.14159
PNW
You felt the need to post in this thread just to correct the way the op says under drive pullies?
And you felt the need to post in this thread just to say that?
Hey, if you guys want to be misunderstood everywhere you go because you don’t know what anything is actually called, that’s on you.
3.14159
PNW
And you guys sure put a lot of effort into making the wrong answers fit the question. I wonder how smart you guys would be if you put that effort into finding the correct answers... guess we’ll never know.
07GtS197
Fort Myers, Fl
Whoa buddy slow down. You come onto a forum to criticize others and think it’ll make you popular around here? Sorry to burst your bubble bud but all youre doing is making enemies. Why not leave the op alone, we all knew what he meant and so did you however you had to criticize him then you say that no one would understand what he meant. Either stop posting like a dick or get out of here.
And yes I didnt add apostrophies in numerous places just for you, are you going to critique me too?
evilcw311
Most Evil Member!
Louisville, KY
Let’s keep it civil guys. Pie we’ve addressed this attitude with you before. We appreciate your knowledge but your approach is unacceptable.
Sit back and relax and realize a lot of people are still learning. No need to come in with an attitude.
This is last warning.
Adam Vinnicombe
Adam Vinnicombe
Sorry if me saying under size pulleys instead of under drive has caused a problem between us all. I am new to the world of mustangs and am still learning so the odd mistake in miss naming an item is going to happen and I do appreciate it when I have made a mistake but there's no reason for people to get all worked up to the point of arguing. Let's all have fun and drive our mustangs the way they were meant to be driven
white95
Apex Junky
Prairieville, LA
Well said.
To contribute to the original post, I'd skip the underdrive/undersize/underspeed/overslow/underwhatever pullies and think of updating more obscure items;
1. Aluminum driveshaft - Less rotating mass spins up quicker
2. Solid or urethane engine mounts
3. Some basic weight reduction can go a long way
4. Light weight wheels [same essential philosophy as #1]
5. Sub frame connectors
It may be a good idea to stash a few pounds where possible and save toward a turbo kit. Then you'd be having too much fun :D
TrickVert
Woodland Park, CO
Yep, you'll be miles (or kilometers) ahead by reducing weight and having the motor in tune versus the minor power improvement you may see from a pulley set.
Suspension and brake upgrades before significantly increasing power are never a bad idea, either. For what it's worth, I reworked my suspension and installed Cobra brakes with stainless-braided lines before adding the Vortech SQ blower to my '95. Those "prep" mods not only got the car ready, but added significantly to general driving enjoyment while I collected parts for the forced induction.
And before anyone says something: Yes, I realize that there are many, many cars on stock brakes and suspension with gobs of power under the hood, but improving chassis rigidity, suspension, and stopping power to match is the better and safer path.
white95
Apex Junky
Prairieville, LA
You won't get any backlash, we prefer to modify everything around here
Adam Vinnicombe
Adam Vinnicombe
I agree with you TrickVert.
Corba calipers, 13" drilled and slotted disc up front, drilled and slotted disc on rear all ready fitted.
I'm running a set of Tokico shocks and struts all round with a 1.5" drop (wish I went lower now)
And a set of 17x10 2003 cobra wheels so it's definitely time to loose some weight
Talking about wheels what size tyres would you lot say I should have on this wheels?
At the moment the fronts are 275/40/17 which seem to work but the rears are I think I little to wide at 315/35/17
302hobronco
Washington
As far as the intake debacle, couldn't you find a good used pi intake off a crown vic 2000 or newer?? I did the underdrive pulleys on my 94 (different engine I know) but I ended up having charging issues and put the stock alt pulley back on. That cured 99% of the issue. Lol. I'm not sure what power increase it did since I did 1.7rr at same time. Point im trying to make is watch out for alternator issues if you do pullies.
Adam Vinnicombe
Adam Vinnicombe
Yes I've read a lot of people had alternator issues after doing the underdrive pullies
SnakeBit!
Florida
I've had udp's on three of my cars, all steeda and skipped the alt pulley each time. otherwise, I was pleased with them. not saying in lieu of other mods, just answering the original question about them.
TrickVert
Woodland Park, CO
Adam, kudos on the brake upgrades. I noticed a great improvement when I did mine. Don't have regrets about not going lower on the suspension. Even 1.5" drop puts the suspension's roll center below the pavement. Somewhere I used to have a link to a great explanation on lowering Mustangs, and why lower is not better past a certain point. The steam-roller 315's look bada$$ on the back of these cars, but they're recommended minimum wheel width is 10.5". I think 295 is the recommended max for 10". That said, if you're not maxing out on cornering, the 315's won't blow up or anything. :)
Markstang73
