Update on Motor
TRUUBLE
-Never Forget-
Here's the latest.
The wear around the ring area of my cylinders was enough that we will have to bore it. So, we are doing custom gas ported pistons. I figured as long as we are waiting for the pistons, I might as well step up on the cam. So the setup will be:
Custom gas ported pistons (4.155") and a 4.100 crank for 444 cubic inches
Changing cam from .720 lift to about 800.
CR will fall from 15:1 to 14.5:1, but that should be better for nitrous
GZ Motorsports Vacuum Pump to provide about 23 hg of vacuum at about 30 cfm for better crankcase ventilation.
Now I need to come up with a 444 emblem . . lol
trav_19
lol get 3 460 emblems haha is that motor a alcohol running machine?? if so for pinks that will hurt you
T
TRUUBLE
-Never Forget-
Yep. It's an alky car. But, when they did Pinks All Out here in Phoenix, half of the top 16 were alky cars.
I was actually thinking about getting 3 442 emblems and using three 4s on each side. :boink:
trav_19
oh yea haha i guess 3 460's would only do one fender haha... :banana: the last all out i watched was a gas vs. alky and the alky guy got stomped because of the continious running of the engines
T
TRUUBLE
-Never Forget-
Did he run out of fuel? Alky stays a lot cooler, so it should be an advantage. My water temp has never been above 180 . . . and I've never even turned on the fan.
trav_19
oh they made a comment about his car getting to hot from running to long and becoming slower and slower
T
TRUUBLE
-Never Forget-
Then something was wrong with his car - but it wasn't the alky that caused it. Alky cars run a lot cooler than gas cars.
Hicks said:
Scarface said:
heck yeah! think you will finally hit 9s?
lol
:rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: I was laughing at that one too......
HECK YEAH !!!!!! :hammer: :hammer: :hammer: :hammer: :hammer:
David is going above and beyond the call of duty to be sure not to violate our language laws :police:
at a boy D, at a boy :drunk:
Hicks
Snakebit said:
Hicks said:
lol
+1
Again :hammer:
T
TRUUBLE
-Never Forget-
I was at 10.19 before. With as well as the suspension is working with the new spool rear end (1.39 60 in Vegas), the added displacement, a taller cam, and the vacuum pump, I'm thinking 9.75-9.80 on motor and middle 8s on the 300 shot.
T
TRUUBLE
-Never Forget-
tRaV_19 said:
....did you go to a smaller gear tad??
I actually went from a 4.30 to a 3.73 and my 60 foot improved from 1.4 to 1.39 . . . which is hard to explain. I think it might have something to do with the efficiency of the spool as opposed to the old locker.
Bottom line is that I couldn't stay with the 4.30 and spray the 300 shot because I would be running out of gear at the top end.
trav_19
do you have a 9" or 8.8?
96GTPlanB
