lutter94
Anyone have one? Looks easy to make, just don't know what the specs are....
Thanks man! I'll look at some pics of the tool and look into it more tonight. I'll let ya know if I need anything else. Thanks again
Sent from my SM-G930V using Tapatalk
[video=youtube;oZ9IKbRu91o]https://www.youtube.com/watch?v=oZ9IKbRu91o[/video]
I have one, here are the dimensions in MM (the battery in my caliper is dead...)
Big disc:
OD 70mm
Center hole 11.5mm (3/8")
11.5mm thick
Small disc:
OD 45.5mm
Center hole 11.5mm
11.5mm thick
Large cup:
ID 60mm
Center Hole 11.5mm
Length 63.5mm
Small cup: Has a bevel on the outside edge to clear the diff.
ID 46.5mm
Center hole 11.5mm
Length 34mm
I hope this helps, let me know if anything is not clear. I can take pics if you need me to.
Robb
Bolt: 3/8x5"
Washers: 3/8 to the length of about an inch
What's the OD's of the cups?
sometimes with the drill they just pop out and sometimes they fight you but its better then owning a tool you will use maybe once every few years if your buddies borrow it.
Right, but if I can make one for free, you won't hear me complaining, lol. Then I can still lend it out, yada yada yada.
I can see that and yet am I the only one that thinks there is a little bit of irony that you will use a drill to make your tool?
