Upper Control Arm Bushing Tool Dimensions
DKblue98GT
I have one, here are the dimensions in MM (the battery in my caliper is dead...)
Big disc:
OD 70mm
Center hole 11.5mm (3/8")
11.5mm thick
Small disc:
OD 45.5mm
Center hole 11.5mm
11.5mm thick
Large cup:
ID 60mm
Center Hole 11.5mm
Length 63.5mm
Small cup: Has a bevel on the outside edge to clear the diff.
ID 46.5mm
Center hole 11.5mm
Length 34mm
I hope this helps, let me know if anything is not clear. I can take pics if you need me to.
Robb
Bolt: 3/8x5"
Washers: 3/8 to the length of about an inch
L
lutter94
South Dakota
Thanks man! I'll look at some pics of the tool and look into it more tonight. I'll let ya know if I need anything else. Thanks again
Sent from my SM-G930V using Tapatalk
DKblue98GT
You are very welcome!
DKblue98GT
[video=youtube;oZ9IKbRu91o]https://www.youtube.com/watch?v=oZ9IKbRu91o[/video]
Wow! I can't imagine it being that easy on a Mustang rear end. Those things are really in there and the shell is steel. It was a lot of work with the rear out of the car and it's even harder with the rear in the car on jack stands...
I used a drill on the front control arm bushings of my Toyota truck and I wish it was as easy as the video makes it look. Obviously I missed something :)
L
lutter94
South Dakota
Big disc:
OD 70mm
11.5mm thick
Small disc:
OD 45.5mm
Center hole 11.5mm
11.5mm thick
Large cup:
ID 60mm
Center Hole 11.5mm
Length 63.5mm
ID 46.5mm
Center hole 11.5mm
Length 34mm
Robb
Bolt: 3/8x5"
What's the OD's of the cups?
sometimes with the drill they just pop out and sometimes they fight you but its better then owning a tool you will use maybe once every few years if your buddies borrow it.
L
lutter94
South Dakota
Right, but if I can make one for free, you won't hear me complaining, lol. Then I can still lend it out, yada yada yada.
I can see that and yet am I the only one that thinks there is a little bit of irony that you will use a drill to make your tool?
stillridin
