Connectorhector
So I'm getting to the final part of my engine build on my 306 and with my 34lbs MAF are some matching USCAR type injectors. (NICE )I think until today while putting the lower intake together I install the heater tube(well I tried)but the adaptor on the injectors make it so you cannot connect at least two of the fuel injectors. The two passenger front fuel injector are too large with the adaptor to fit. DO NOT GET USCAR TYPE FUEL INJECTORS WITH THE ADAPTOR FOR YOUR 95 unless you want to modify your heater tube. In my build I just deleted the tube for now and put the sensor( with a half inch to three eighths brass adaptor), to the hole where the heater tube was screwed into the intake and blocked the lower return tube on the water pump. I'm sure I can find a three way fitting that will work, ill change it later. No heat for now I guess. I'm only up in Calgary Alberta. Who needs heat. My igloo is nice and toasty. Lol
