Vacuum question
95_saleen
My egr has vacuum at idle is it supposed to? (i didnt think it was supposed to) feeling kinda confused,not finding much on line about how the vacuum lines go for 94-95 mustangs..side note i have a trickflow intake
96blak54
Staff member
Lawrenceburg Kentucky
I dont know what to tell you! Im not to sure any of the others here can too. Most of us just delete it.
If the valve vac line has vac at the wrong timing, trace the vac line on back to the air selenoid. It could be at fault
95_saleen
I think im getting it. The vac line from intake was going to a Tee and straight to the egr i have rerouted the vac lines and she is idling smooth as can be now. But now i have a high idle, on to that problem . I noticed the idle screw is almost all the way in so im thinking the previous owner adjusted it trying to get the car to idle.
evilcw311
Most Evil Member!
Louisville, KY
Are you in an area that does inspections or emissions testing??
95_saleen
it wouldn't be a big deal,nobody checks that stuff around here. Im just working all the problems out and getting the car right before i add heads and cam.........or a 408.......... Probably just heads and cam for now.
evilcw311
Most Evil Member!
Louisville, KY
If your gonna do heads and a cam then you will need a tune. Might as well eliminate the egr at the same time. It cleans up a lot on that side of the motor and the egr doesn’t really do much for our motors.
Just my ¢.02
