Valve Clearance
94 DropTop
Do I need to check my clearance with e7 heads and an e cam w/ 1.7 rockers? I would assume that I would be fine.but figured what I see what you guys say.
GDTrumbo
Nashville, TN
With the rockers, I would check. Also check the contact pattern on the valve tips to be sure an alternate pushrod length isn't necessary.
GT
LAFENATU
Definitley check. That may work ok on john doe's car but yours may not.
Clay the heads and check. I assume you have better valve springs? If not you're gonna need them.
94 DropTop
ya the heads cam with a nice set of dual valve springs, that were running on a bigger cam than mine.
