valve cover clearence issues
Johnny95
I'm sure this has been addressed many times before but I'm trying to run a set of ford racing tall aluminum valve covers and ofcorse there hitting the iac. Am I fighting a loosing battle with these covers I'm running a track heat with a 1" spacer heads are trick flow 170 with stud mounted roller rockers.. will I have altinator problems will the fox style stock vc work...? Thanks
lilj4u2njoy
Forest City, NC
I run the tall valve covers aswell, with a one inch spacer, what I did was pulle the tb and iac off and just used a grinder and cut off that bottom corner, enough for it to fit and still use a bolt... No issues
GeeTeeFiveOh
Barrie Ontario
It's said that fox valve covers fit rollers and alternator with minor grinding if any. No personal experience. I have tall moroso covers and they are way too much effort to make work for me what with grinding the IAC
BYEBYE2U
North carolina
I run a set of tall covers with a fox setup and no elbow.I have a 1 inch spacer on a Holley systemax and my trouble was with it hitting the rear of the although.I had to end up grinding it down some.
