Valve Covers
AaRoN
King Post Whore
I painted mine when I swapped motors.
switch96
Well, I was referring to 4v valve covers, but they're probably the same material.
Yours look pretty good. Sand and spray?
switch96
That will definitely happen further down the road. Painted them tonight, pics tomorrow.
switch96
I had some in another thread but they got deleted. When I get home from work I'll repost :grin:
switch96
Painted some other stuff too :headbang: I do not, in any way shape or form, under any circumstances, reccomend removing 4v cam covers with the engine in the car. Ridiculous.
duff daddy
2v FTW :)
JeremyAlan
SN95 Supporting Member
Suffolk, England
Awesome.
I heard about taking off the valve covers and it being a tight fit... thats why when i put the heads on my GT I'll be pulling the motor.
duff daddy
JeremyAlan said:
Awesome.
you have to pull the motor to get 2v heads off and i wouldnt "pull it" i would drop it out the bottom with the k member and trans still attached...
JeremyAlan
Suffolk, England
Never thought of that... I assume that is easier? What if you are in your two-car garage and dont have access to one of those fancy lifts?
would you just have to jack the body up while the K-member stayed on the ground?
TxCobrA98
timing chain cover, upper intake cover, and valve covers powdercoated satin black during my engine rebuild.
dafizuck
Switch... I think you shouldve gone red, unless you put a little more blue in the engine bay. JMO.
