very bad oil leak
akaslick15
well what can i say im having oil leaks in the garage and there as big as my head i changed my oil 3200 miles ago and yesterday i changed my oil and noticed there was maybe 2 quarts in the pan pretty f*ked up ino and the oil was blacker then black... the oil is leaking right in the middle of the pan my question is can it be the pan that busted or the seal is bad i would really appreciate it if you guys would help me out asap i really need to get this fixed!!!
dczsvt
Marshall, Missouri, United States
only thing i can suggest is get under the car and look...it may look like its dripping from the middle of the pan but could it be coming from your front seal? clean it up, top it off with oil and drive for a bit, get back underneath and see if you can find anything.....i gotta fix some leaks on mine too, both front and rear seals
mustangspartan
MN
Going with what the person above me stated i would get the UV dye also put that in after you clean it all up and look at it with the light see exactly were it starts.
akaslick15
akaslick15
can i use like a flashlight for the uv dye or do i need those special lights for it?
