very high idle after nitrous backfire
shorty
raced last night, raped up the rpms a little to high had a nitrous backfire
Now the car idles at like 3500-4k
but if i unplug the MAF, it idles down. sounds like shit but it does idle down.
im thinking it blew the MAF
Musturd
There's a good chance you blew the maf ... Are you running a window switch or are you a crazy mofo like me , I power shifted on the bottle all Saturday night with no window switch like a asshole ... A friends 08 gt was having issues similar to what ur saying, happened like 3 runs in a row the other night it's a auto though. It actually destroyed the cone filter
shorty
shorty
wth, i just posted a big reply
Yea i run a window swtich, i have some big balls but not big enough to not have some type of safety on a 240k mile stock motor and a 125 hit lol
as far as a leak in the intake, i would think that even when the MAF is unplugged the vacume would still cause a high idle? could be wrong on that
shorty
shorty
its possible. im going to throw a buddys MAF in after work today and see what it does, if it still idles high, then off comes then intake
shorty
shorty
replaced MAF and IAC no change. i decided to drive it and see how it acts. and omg does it miss
MustangChris
Aurora, CO
you inspected the plugs yet?
whats your car, again? Things could be a bit different from the 5.0s to the 4.6s... for example, you may have cracked the plastic intake manifold on the 4.6; or you could have some kind of leak between the intakes on the 5.0....
shorty
shorty
Stock 5.0
yea, pulled the plugs today, all look good. Also did a compression test and have 120,120,120,120,90,120,110,123.
I dont think its causing my rev issue. unless a valve isn't seating and fuel is being dumped into it?
going to check for a leak in the intake tomorrow.
and yea, i plan on spraying it again
Check your vac tree and all the intake soft lines. One is probably off or the vac tree is split. A Fox guy locally blew his vac tree in half after a N2O backfire.
shorty
shorty
Vacuum tree looks fine, as does the upper intake. Pulling the lower today. all vacuum lines look good. I was able to lower the idle before i pulled the intake to about 1100, but something still isn't right. I shouldn't have to bottom out the idle screw for it to hit 1100.
shorty
shorty
ATC sensor!!!!!! replaced and we are now back to normal
99GreenStang
I THINK! not sure an atc sensor would be an Air temperature Control Sensor am i right ??
5jvenom
could be a lot of things...even a small crack in the intake and vacuum leak would cause it..
