Vortech SQ Trim
Brian95SVT
Chesapeake, VA
So I am thinking about taking out a 5,000 loan and getting some parts.
Vortech SQ Trim S/C kit is the big thing. I was wondering where people say to get them from. I've found some but lowest I've found is $3,699.... that's pricey....
Links?
97stanger
Just an FYI, MPH doesnt advertise that they do a 96-98 mongoose kit because they dont have any tunes to send you, but they do do one. thats what i got, and i believe i spent about $3600, but that also included their boost pipe which i believe runs about $250??
B
Brian95SVT
Chesapeake, VA
See I though Vortechs were like 2,300 for a kit because everyone says they are cheaper than Prochargers but they seem to be around the same prices....
DropTopPony
South Jersey
Thats a tuner kit, doesn't include tune/injectors/fuel pump etc....just the basics.
Its going to run $3500+ for a complete kit.
DropTopPony
South Jersey
B
Brian95SVT
Chesapeake, VA
The JMS Velocity Supercharger Kit includes:
Vortech V2-SQ S-Trim Tuner Kit
60lb Siemens/Deka Fuel Injector Set
Walbro 255lph Intank Fuel Pump
SCT BA-2400 90mm Big Air MAF Meter
JMS Custom Tuned SCT XCalibrator 2 with 3 Custom Programs (UNLIKE OTHER COMPANIES WHO CHARGE EXTRA FOR THE TUNES) and User Adjustable Features!
NGK TR6 Spark Plugs
SCT XCalibrator 2 User Adjustable Features:
Wide Open Throttle:
-6% Leaner to 14% Richer
Global Spark:
-5 to +5 degrees
RPM Adjustment Spark:
0 - 2000RPM: -14 to +4 degrees
2000 - 4000RPM: -8 to +4 degrees
4000 - 8000RPM: -8 to +4 degrees
Diagnose Check Engine Lights & Clear Trouble Codes
Gear Ratio Selection:
2.73 to 5.14 Ratios
MAF Meter Selection:
80mm to 90mm Lightning SCT Big Air BA-2400 & BA-2800 MAF Meters
Tire Size Selection:
205/65/15 to 315/35/19
Fuel Injector Size Selection:
19lb to 60lb Fuel Injectors
Idle RPM: -300 to +300RPM
Cooling Fan: On / Off Temp
Traction Control: On / Off
Two Step: On / Off & RPM
Automatic Transmission Shift Schedule:
WOT 1st - 2nd: -3 to +7mph
WOT 2nd - 3rd: -4 to +8mph
WOT 3rd - 4th: -5 to +10mph
WOT 4th - 5th: -5 to +10mph
96 - 98 Mustang GT Vortech Velocity Supercharger Kit $3,699.00
Select Supercharger Finish: Satin
AFM Power Pipe Upgrade: No Upgrade
Aftercooler Upgrade: No Upgrade
Vortech Head Unit Upgrade: No Upgrade
Water Methanol Upgrade: No Upgrade
T-Rex Fuel Pump Kit: No Uprade
Sub-Total: $3,699.00
Now some of those parts like the 60lb injectors and the 90mm TB.... do I really need those? or do I have to have them with this kit?
I mean they come in the package and I can't take them out but damn those are HUGE
Jrgunn5150
Call them up and see if you can swap for 42's and a lightning MAF. That's all I ran to 500 rwhp, it was holding me back from making more power though, my bottom end would have sneezed at 700.
Jrgunn5150
:dancing6: :dancing6: :dancing6: :dancing6: :dancing6: :dancing6: :dancing6: :dancing6: :dancing6: :dancing6: :dancing6: :dancing6: :dancing6: :dancing6: :dancing6:
B
Brian95SVT
Chesapeake, VA
Well the Velocity kit comes with a SCT tune/tuner so I can just tune the injectors with less pressure and run them as a 42lb so i will be good. the MAF I think I will stick with and just see what happens ahha.
B
Brian95SVT
Chesapeake, VA
I found one for like 2,400 but i'm not sure if I can get it or not. The site didn't have it on there but on corral.net he posted saying he had them for our motors....
voidfinger
i've seen some where they would do deals for site members...
one question though guys, with a tuner kit... what all comes with them? everything but the pump, injectors, and maf right? would it be cheaper to buy the tuner kit and piece the rest together?
