Water Pump Troubles Need a lil Help..
silvergtstang_94
Ok i had a water leak and i thought that it was coming from were the pump seals to the plate but its coming from the next plate that meets the block...How do i get to that plate to change the gasket? Also which gasket is that?....Also i broke the top right bolt in the water pump off..It broke pretty far back in there..Any way to get it out? Or is there any thing else i can do? :crying:
Paul
Pull the timing cover, clean all surfaces, extract broken bolts as necessary, replace with stainless bolts that won't rust, ( :) ) and reisntall.
Paul.
silvergtstang_94
Paul.
Alrighty I'll do that...What about were the timing cover hits the oil pan? Wont it leak around the pan if i take it off...Also will the balancer need to be removed?
Paul
You should drain the coolant. Yes, the balancer needs to come off to remove the timing cover. Drain the oil too.
Paul.
silvergtstang_94
Paul.
I already got the coolant drained and i gotta change the oil so thats cool...But wont it leak around were the pan meets the cover...or do i just rtv the heck outa it? lol :thumb:
Paul
You'll need to replace all of the front cover gaskets - that's one between the pan and the timing cover is one of them.
Unless you have a once-piece pan gasket - in which case you just need some RTV around the corners.
Paul.
94Pro-5.0
Little Elm, TX
and if you dont have a one peice get one while you have the pan off. they are nice, i like having a re-usable pan gasket.
