Water Wetter
svt-sinister
Well i just got my car finished and in traffic the temp gets to about 210. Was wondering if anyone had any experience with water wetter to see if it really helps. If so, what was the mixing ration? Thanks
duff daddy
water wetter works ok, but if your around where its gonna be freezing i would suggest to use RV coolant, its good to the high temps and lower temps as well, its what i use in my motorcycle, and if you do a track day it wont make the track slippery tooooo!!!!
2slo95fiveoh
Lawrence, Kansas
Water Wetter is made to work with only H2o, since that is the liquid that dissapates most of the heat.. Antifreeze does raise the
boiling point of water, but it also lowers the freezing point of the mixture as well.. For a street car, and $6 a bottle, it's not worth it..
Just flush your cooling system with your heater on high, and get a good 50/50 mixture, and your should be set.
svt-sinister
ok well i added a bottle to my 50/50 mix. Believe it or not but it does help. My temp never goes to or pass 200. Before it went 210
