Weird noise coming form the rear end.
jfor441
It is only happening when I make a left hand turn. Sounds like a rubbing noise. It happens everytime I turn left though. Anyone have any ideas? Is the rearend going out?
95-stang
Might be the left hand side half-shaft bearing, but i would be tempted to jack it up safely and remove the wheel just to check its not the caliper or something in that region.
Are you running very wide rims or wide tyres?
J
jfor441
its not the calipers I know that for a fact. I am running 03 cobra rims. 17x9 rims with 275/40x17 tires.
95-stang
In that case its unlikely to be wheels and rims, still worth jacking it up and seeing if there's any play in that side.
J
jfor441
well... put the rear up on jackstands and everything was fine. could not recreate the noise whatsoever. went for a drive and EVERYTIME I turned left there was the noise.
