So as the title says I am getting a vibration from my passenger side front tire area. Anything over 40mph it is noticeable.
Symptoms:
It gets worse as the speed increases.
However when I turn slightly to the left it goes almost completely away.
If I turn to the right however it gets a lot worse.
If I apply braking the vibration decreases to where it is barely noticeable.
There is also a constant squeaking that seems to go with the rotational speed. (this also occurs at low speeds)
My thoughts are possible bent rim (unlikely), tie rod end, rotor (also unlikely less than 2k miles on them), wheel bearing?, tire defect.
I did jack the car up and spin the tire but everything seemed normal. Took the tire off spun the rotor..again normal.
Any thoughts suggestions are appreciated!
Symptoms:
