Wet/Dry System
cornhusker
I'm looking into a nitrous install but I don't know either if the wet or dry would be better? I heard to avoid the wet system
2002BLGT
Bedford VA
How much are you going to spray ? if its a dry shot you just have to make sure you dont go beyond the capabilities of your current fuel system to add enough fuel safely , the reason most people go wet is because its safer at higher HP levels , wet is also easier to tune
CanaryGT
Phoenix
What have you heard about avoiding wet systems. I almost always hear wet is superior to dry systems.
96_SVT_Cobra
SN95 Supporting Member
Orlando
dry would require more tuning and larger injectors since the dry kit only sends nitrous and relies on ur fuel system to compensate the needed fuel. where as a wet kit you have a nitrous and fuel solenoid which inject both on top of ur regular fuel system so u dont need even bigger injectors than whats necessary for your motor n/a.
C
cornhusker
Read some applications on sites like summit. Says race fuel required, will it work with 91octane
LAFENATU
I like wet kits better, they are not injector dependent and no, race fuel is required at all for nitrous - wet or dry.
As a general rule the higher the octane the better so I would do 91 or higher if you're gonna spray it.
www.nitrousexpress.com
Here are the 2 things I would have if I was to run my car. I am a big fan of NX, they make high quality stuff and are top notch.
http://www.nitrousexpress.com/product-details.php?id=906
http://www.nitrousexpress.com/product-details.php?id=1357
