What clutch should i get!?!?!?
smasher41
does the fidanzia flywheel need to be balanced prior to mounting, i didnt see any mentioning of it already balanced or not.
they also sell a forged steel version.... whats ther difference in using a heavier flywheel? doesnt stall out as easy?
I've got a king cobra currently...not bad, but I don't know if I would recommend it.
The reason its so cheap is because its a ford truck clutch put in a mustang :D
scarface
Guest
I just bought it and installed.
Jrgunn5150
Whatever you get, use the Ford throw out bearing, they last alot longer. And I would recomend skipping on Spec clutches altogether, I had 2 and they both chattered and sucked.
And yes, a heavier flywheel would keep the car from stalling more, but it may be SFI certified, or cheaper.
smasher41
Anyone one try the tikmen TOB , they claim to not whine/chirp like the ford tob and last just as long.
my list will be the centerforce dual friction, Spec flywheel ( made by fidanza, and carried by mustangs unlimited which is near my house) new clutch fork, tikmen or ford TOB, ford Pilot bearing, new flywheel and clutch bolts.
anything im missing?
