Mustanger
Question for you all...I was out in the 94 GT today just driving easy & enjoying it, stopped at a red light & popped the Steeda TriAx into neutral to rest my clutch leg. When I went to go into first gear the TriAx got totally loose & floppy! No connection to the tranny it felt like & no spring tension on the shifter handle. I haven't had time to go pull it off yet & check it out, for sure tomorrow, but is there anything in the T5 tranny that could cause this? I finally got it to go into second I think & drove home in one gear only. The shifter handle is way cocked over & up tight to the dash! Clutch works fine no noise or anything from the tranny area so I am fairly sure it is shifter related. It is jammed in the one gear & I don't want to apply too much pressure til I look tomorrow.
Any ideas? I never heard of a TriAx breaking before have any of you? Sure hope that's it as it is way cheaper to fix! Thanks all.
