What Do You Guys Think?
19mustang95
uncltrvlnmatt said:
The front end kit came with a rack and pinion. The bottom hole in the pic is where the steering column goes through the fire wall. I just need to finish the steering modification, but I want to get the brakes set up first.
Apparently the 99-04 V-6 master cylinder has horizontal mounting bolts instead of vertical like on the Mach. Since that is the case I will be able to rotate the hydroboost 90* for better clearance.
i'm not sure if you know this, but the 99-04 V6 doesnt have hydroboost.. and im saying about the hyrdoboost connecting to the actual rack and pinion.
but you may want to check on modularfords.com, there are quite a few people that have put modulars into older mustangs..
U
uncltrvlnmatt
Pa.
Thats where I found out about useing the master cylinder from a 99-04 V-6. A guy did that on his car.
