Mar 1, 2009 #1 S slopony Member Joined Nov 12, 2008 Messages 184 Reaction score 0 I think I might have just picked up a used powerdyne s-trim. what size fuel pump should I get. should I get a 190 lph or go for the 255 lph?
Mar 1, 2009 #2 L LAFENATU Well-Known Member Joined Nov 25, 2007 Messages 3,555 Reaction score 1 First find out what blower it is. You named 2 different superchargers. The S-trim is made by vortech, and powerdyne makes the BD11, BD11a, and the XB-1. Get a walbro GSS340. It is a hi pressure 255lph.
Mar 1, 2009 #3 OP OP S slopony Member Joined Nov 12, 2008 Messages 184 Reaction score 0 its a bd11 or bd11a. not totally sure which one. do you know the difference between them?
Mar 1, 2009 #4 L LAFENATU Well-Known Member Joined Nov 25, 2007 Messages 3,555 Reaction score 1 The bd11a is an updated bd11. I believe it has a kevlar belt.. All the powerdynes except the XB-1 are not designed for big power. Usually no more than a 9 psi pulley, obviously the boost number is based on resistance.
Mar 1, 2009 #5 OP OP S slopony Member Joined Nov 12, 2008 Messages 184 Reaction score 0 i'm pretty sure it's the bd11a. so just do the 255 lph and be done or go with the 190 lph. I'm planning on doing heads in the future and running 9 psi then.
Mar 1, 2009 #6 S Spd0lit Active Member Joined Jan 26, 2007 Messages 579 Reaction score 10 Location SoCal get the 255 for forced induction apps it will let you grow in the future a little.
Mar 3, 2009 #7 OP OP S slopony Member Joined Nov 12, 2008 Messages 184 Reaction score 0 thanks for the input. Get a walbro GSS340. It is a hi pressure 255lph. Click to expand... found one on ebay for 94 bucks. :headbang:
Mar 3, 2009 #8 ProKiller Well-Known Member Joined Jan 27, 2006 Messages 3,070 Reaction score 200 Location PA make sure its the high pressure and not the high volume pump. the high volume is for NA.
Mar 3, 2009 #9 G GearGambler Member Joined Jan 30, 2009 Messages 227 Reaction score 0 Location Northeast PA i believe the gss340 is high pressure, high volume (255lph) i think the gss306 is the high volume (255lph) someone correct me if i'm wrong...
Mar 3, 2009 #10 L LAFENATU Well-Known Member Joined Nov 25, 2007 Messages 3,555 Reaction score 1 Correct... You want the GSS340. That is the walbro hi pressure 255lph fuel pump.
Mar 4, 2009 #11 OP OP S slopony Member Joined Nov 12, 2008 Messages 184 Reaction score 0 I got the gss340. it said it was high pressure hi volume
