what fuel pump for s-trim
slopony
I think I might have just picked up a used powerdyne s-trim. what size fuel pump should I get. should I get a 190 lph or go for the 255 lph?
LAFENATU
First find out what blower it is.
You named 2 different superchargers. The S-trim is made by vortech, and powerdyne makes the BD11, BD11a, and the XB-1.
Get a walbro GSS340. It is a hi pressure 255lph.
slopony
its a bd11 or bd11a. not totally sure which one. do you know the difference between them?
LAFENATU
The bd11a is an updated bd11. I believe it has a kevlar belt..
All the powerdynes except the XB-1 are not designed for big power.
Usually no more than a 9 psi pulley, obviously the boost number is based on resistance.
slopony
i'm pretty sure it's the bd11a. so just do the 255 lph and be done or go with the 190 lph. I'm planning on doing heads in the future and running 9 psi then.
Spd0lit
SoCal
get the 255 for forced induction apps it will let you grow in the future a little.
ProKiller
PA
make sure its the high pressure and not the high volume pump. the high volume is for NA.
GearGambler
Northeast PA
i believe the gss340 is high pressure, high volume (255lph)
i think the gss306 is the high volume (255lph)
someone correct me if i'm wrong...
LAFENATU
Correct...
You want the GSS340. That is the walbro hi pressure 255lph fuel pump.
