what spark plugs you running
smokedya2
Lemoyne Ohio
What kind of spark plugs should I run in my car. Autolite forced induction fire or ngk's
I have a pro charger set up
Saint
Motorcraft ASF42C on a N/A 306
Previously worked at a speed shop, NGK's are what you want for a procharger setup I'd probably put V-Powers
Be sure to check them after a day of driving with them in to make sure there's no detonation.
I had NGK V-powers on mine and they sucked.
Last year I changed back to motorcraft and haven't had a problem since.
smokedya2
Lemoyne Ohio
I have mine tuned to 93 w/ 8lbs of boost I guess once I get her put all back together and dynoed I guess I find out which plug will be tye better one.
kb1982
Kentucky
I use the NGk's gapped around 28 with 16lbs of boost. A testament to the NGK's, alot of sportbikes come from the factory with them, most commonly the cr9e plug. There is alot of cyclinder pressure in those engines
EdgarR213
Staff online
