what to use to build a bad ass 4.6L
cody0170
ok so i was over at my dads yesterday and we were talking about what might be a good way to make some more hp. i currently have
mac h pipe, 40 flows, bbk cai, bbk tb, bbk plenum, underdrive pulleys 50-150 NX nitrous, msd coil packs, msd wires, 410 hears.
just am not sattisfied. so i am considering on going into the motor but i dont have any idea of a good package to work with. working with a budget and am wanting to be to 12's something to low 13's. 113k miles
Shocker98GT
PI swap or intake/cam swap (may as well go aftermarket if you're getting new cams IMO)
PI swap would be great, 10.5:1 is a good compression ratio for nitrous
ck5.0
I just did some new cams and PI intake swap in mine. The car runs a hundred times better (it ran well before) and it pulls much harder. Its a fairly cheap but good power upgrade. If you get a set of PI heads it will bump your compression. Compression is good for nitrous.
DropTopPony
South Jersey
since you already have the juice, i'd go with what everyone is saying and find a cheap PI swap and find some used VT stage 1 or 2 NA cams and that will easily get you into the 12's with that 100 shot.
C
cody0170
what year pi heads to go with. just curious cause ive heard something about pressed cam gears
voidfinger
well i guess you could get the non pressed but i prefure them... Even though they are not 100% on time but then again i don't want to do it wrong so... But any would work 99 up.
I got a set of 99 up Truck heads so :)
C
cody0170
ok well im looking at a set of 01 heads that are told to be factory complete. what would i need to do to them if i want to run a vt stage 1 cams.
tooslow
i've seen them bought and sold for $300-400 all over the place.
i just can't remember if that was assembled and with or without cams.
a couple guys here deal with them a lot more than i, so i'm sure they'll give a better answer.
voidfinger
Jrgunn5150 said:
I got my first set for 250 with cams, assembled, but no more than 400.
Yea i got mine for a steal of 200 but they need some new seals so thats a little bit more :)
ck5.0
I did not do heads but I only paid 100 total for my PI cams and intake.
C
cody0170
when you did the cams, how was that was it a pain in the ass. did you see good results. is it worth swapping out the heads if you dont port?
Jrgunn5150
Cams are tedious to swap in the car. I know some people have luck without remoiving the chain, but I would set aside a day for it nonetheless, just in case you do need to pull the cover. Just take your time and it's pretty straightforward.
Swapping the heads with stock cams is not worth the effort, IMO. You'll only be 15 rwhp ahead of the game, tops, with an entire extra day of effort and more money in part's. Porting is pretty worthless without cams to back it up also. You could always swap in the PI cams, and save to either have the NPI set-up to run big lift cams, or get some ported PI's and cams.
Most people with just an intake and cam swap report better throttle response and riveability also.
