What type of intake with a Kenne Bell?
94califiveoh
Im just curious to know what type of air intake i can run if I want 42lb injectors. I dont know if someone makes one or not but I cant seem to find a MAF for 42lb injectors. I currently have a BBk CAI but I want to know what would be better with the Kenne Bell.
Or if its easier, would 30lb injectors be ok for 8lbs of boost? im looking at abour 375-400 hp...
94califiveoh
5.0, Trickflow heads, stock cam, long tubes, 75mm TB.
Do I even need 42lbs? or Would 30lbs be ok?
94califiveoh
I wanted to keep my BBK CAI and I can only find a MAF that goes upto 30lbs. Is there any outthere that would work for bigger injectors and be calibrated for a CAI?
LAFENATU
94califiveoh
^^^I dont think I can use that meter with my bbk intake. I want to be able to pull air from the fender not from the engine bay
forcefed5pt0
charlotte nc
get the kenne bell 90mm mass air/ ford lighting and have it calibrated for 42lbs. if u can get 30s id use them, the 42s killed my gas mileage, and even makes warm startups hard
toyman
Ford meters cannot be calibrated. The calibration is in the tune. As to whether you need 42's or something else is determined by your fuel needs. There are formulas out there to help you do the calculation.
toyman
The LMAF is 90mm. I'm guessing that is larger than the CAI. You will probably need an adapter with the LMAF.
