Whats wrong w/ my gauge cluster?
Venom351R
Maine
I have a 2000 Ford Ranger 4x4 Extended cab. The gauge cluster is all screwed up. My oil pressure does not register until after about 10 mins of driving, my gas level only goes as high as 1/4 of a tank from full and recently the water temp gauge has become stuck. First it was stuck half way between the C and the H it would not go down even after the truck sat all night when I went to leave in the morning it would still be at half way and now its stuck at straight up almost on the H. I dont belive its over heating its never had that issue I just think the gauge is screwed up. Any idea's on whats causing this and how to fix it. I dont care as much about the other ones as much as the water temp one
Win
Kennesaw, Ga
EastBayStang98 said:
ur gears in the back might be screwed
It should be electrical i think being a 2000
I would check the connection or see if you have any blown fuses anywhere.
Venom351R
Venom351R
Maine
I'll go through the fuses tomorrow and if that does not yield anything I'll see if I can pull the assembly out and see whats going on
Venom351R
Venom351R
Maine
Not any fuses, Im going to make a run to the transfer station soon and I'll check the upper radiator hose just to make sure its not the T stat sticking, wonder if the temp sending unit could have taken a crap.
