98mstanggt
Would 1 inch wheel spacers work with 17x10 Bullitts :dontknow: need some info before i purchase them. The car will be lowered using Eibach Sportline Springs also.
Well i just brought some Chrome Bullitts from a friend for $300 17x9/17x10.5 the front have Bfgoodrich 275/40/17 and the back need new tires so Ima put Nittos 555r 315/35/17. I have heard the 275/40/17 have clearance issue with the inside fender im also dropping the car with sportline springs will this work.justinschmidt1 said:You should be fine with a 1/2 inch spacer
I kinda figure you couldnt probably turn all the way is/was your car lowered??justinschmidt1 said:I ran 18s and 275s for months
The only problem I ever had was you cant turn full tilt without rubbing.
